I have had my PSW 202 for about 3-4 years now and recently my sub just died. I took it apart yesterday and found a spot where a fuse went in and saw that the fuse that was in there was blown. I figured that was the problem, but when i put the replacement fuse in and plug it into the wall and make sure the power is off, the fuse blows right when its plugged in. I made sure it was a 250v GMA type which is just like the original one. I cant figure out what the problem is and some professional help would be nice, and/or any help.
hi! i have a psw202 from 2002, and i have the same problem with the fuse.If you have found the answer to these problem,please told me. Im looking the PCB and the only thing that I seems suspicios is the big integrated (TDA 7294) looks a little bit damaged. Thankyou!!
