Phillips FW-C70 help. back speakers dont work.
Username: Potatoguy
i have had this system for a long time. i want to hook up the rear speakers but they dont work. well the actual speakers are fine, i tested them. but nothing works in the input. i cracked the box open but i cant see inside the back enough to see if a wire is loose or who knows what. any have any ideas or help?
Username: Potatoguy
i twisted the wires like i found in a previous post, but are the rear spearks in their own slot worth it? and again, any adive on fixing.
Need to Register?
Forgot Password?
Enable HTML code in message
