Active vs passive X-over
Username: Touche6784
Post Number: 1158
I think this was discussed before but I can't find the thread. I am in the process of making external crossovers for my new maggies and was wondering what difference in sound I would have if I use active electronic crossovers?
Username: Arande2
400dB could probably d..., 4000 isnt ev... 100,000dB FU...
Post Number: 653
I don't know, but I do like the advantage of more control with active. I don't know about the sound. SORRY for wasting your time?
Username: Timn8ter
Seattle, WA USA
Post Number: 1180
In theory, active crossovers with dedicated amplifiers for each section are superior in every aspect (except cost) to passive crossovers.
I've not met anyone that thought systems using active crossovers sounded worse than passive.
Username: Gamerdude
Ontario Canada
Post Number: 356
My dad has some audiocontrol ones and he's allawsy saying get those "hammer smaching ones" out and go active. He says he will save power from the amp, which is true but doesnt bothor me there really isnt but in the sound department ecccept being louder becuase its like a direct route to the speakers in stead of going threw the copper coils
Allso there more for concerts and movies from what i heard
Username: Jan_b_vigne
Dallas, TX
Post Number: 9623
http://sound.westhost.com/site-map.htm
https://www.ecoustics.com/electronics/forum/home-audio/308495.html
Username: Timn8ter
Seattle, WA USA
Post Number: 1181
The main point to take away is that the amplifier is connected directly to the driver meaning the driver has the full amount of control the amp can provide.
Post Number: 1159
How much would the average decent quality active XO cost me and what brand? Thanks for the links and posts.
Username: Timn8ter
Seattle, WA USA
Post Number: 1182
Kit
http://www.marchandelec.com/xovers.html
DIY
http://www.snippets.org/filters/crossover.htm
or....
http://www.deqx.com/stereo.html
Username: Frank_abela
Berkshire UK
Post Number: 1826
My understanding is that in theory, active crossovers typically have about 10 times less distortion than the higher powered passive crossovers required to drive the same speakers.
However, I've heard active systems on a few occasions (not recently I admit), and I have always found that the cost/performance ratio doesn't stack up. i.e. if you have 2 stereo amplifiers to drive the two sections of the speaker and add in the cost of the active crossover, is this a better result than one better amplifier into passive crossovers into the same speakers? Very often I find that the passive solution is better. I can only assume that this is because the weaknesses of the 2 less capable amplifiers are a worse problem to have than the weaknesses of the passive crossovers.
Regards,
Frank.
Username: Timn8ter
Seattle, WA USA
Post Number: 1183
....until now
Username: Stefanom
Vienna, VA United States
Post Number: 291
The active ultra-high slope x-o in the latest NHT has definitely piqued my interest. Of course the DEQX does much much more than that, but still, its pretty neat stuff. Of course their 2.1 system is 6k, but thats with everything. It is on my short list to audition.
Username: Gamerdude
Ontario Canada
Post Number: 358
Audiocontrol
