Bronze Member Username: DevelaraPost Number: 11 Registered: Dec-06 | Hi Has any one tried Alchemist Axiom Apd 26a integrated amp.... hows the quality , i am trying to buy a second hand which i will couple it with Wharfedale Evo 8 or Castle Isis series bookshelf speakers , any reviews on the amp? dev. |
Gold Member Username: T_bomb25Dayton, Ohio United States Post Number: 1499 Registered: Jun-05 | Mark Shifter the owner of av123 used to own this company and as far as i know and knowing Mark he still built great stuff back then,you might want to go over to the: www.av123.com and get on their forums,im sure you will find what you need to know. |
Gold Member Username: T_bomb25Dayton, Ohio United States Post Number: 1500 Registered: Jun-05 | I think hold that thought I'll find out if its the same company. |
New member Username: MarkdavidPost Number: 1 Registered: Feb-07 | It is very unfortunate that this company is closed .I used to own some of their products .Its very good in sound and also in buit .I think u can use both wharfedale and castle .it will make both ur speakers sound neutral.use proper cables and also check ur acoustics. mark |
