New member Username: ThereverendPost Number: 7 Registered: Dec-06 | I am looking to replace my old and nearing death pioneer turntable that I saved from my girlfriend's dad's trash heap. It works but has a few issues. Anyway, I would like to upgrade and buy a nicer one. I am looking to spend around $200 max, but perhaps I can go up a little. I was looking at the Rega P1, it seems very nice for a beginner but it is too expensive right now (college student). I am willing to buy from ebay. What are my best bets? Colin |
Silver Member Username: Daniel_canadaCanada Post Number: 255 Registered: May-06 | P1 on Ebay? |
New member Username: ThereverendPost Number: 8 Registered: Dec-06 | It seemed like all I could find was the P1 for retail. |
Silver Member Username: Daniel_canadaCanada Post Number: 257 Registered: May-06 | Any dealers in the area that sell used gear? P1 or a Debut. |
New member Username: RyukyuPost Number: 8 Registered: Dec-06 | Audio Technica (AT-PL120) makes one that some people seem to like. There's a thread over at AudioReview Forums about it. Here's a link to check out :http://www.amazon.com/gp/product/B00012EYNG |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 3765 Registered: Feb-05 | Best new inexpensive turntables on the market are; 1)Rega P1 2)Project Debut 3 3)Music Hall MMF 2.1 All of these tables exceed $300 in price but come fitted with fine budget cartridges. They are in the order of my preference. Stretch the budget a little further and you could look at the Rega P2 fitted with a Bias 2 cartridge. I know of no new tables at $200 that make music. Good luck. |
New member Username: ThereverendPost Number: 9 Registered: Dec-06 | How about some good used ones? I was looking today at a used Yamaha YP-B4 that the record store manager swore was better than a modern Rega. Since I don't know much, I don't really know any better than that. If anyone thinks this would be a good TT, I might go buy it tomorrow, it was only $150. |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 3767 Registered: Feb-05 | Good luck....you'll probably need it. |
New member Username: ThereverendPost Number: 10 Registered: Dec-06 | Ok... well I did a little more research tonight, I think I will skip the Yamaha. Why do you say I will need good luck? I am just looking for recommendations for a solid entry level at not too much money. Oh well, maybe that does require luck. Any vintage brands that I should look at? How about Dual, Thorens, B&O? Are these solid or will I be wasting my money? Thanks. |
Silver Member Username: Arande2400dB could probably d..., 4000 isnt ev... 100,000dB FU... Post Number: 613 Registered: Dec-06 | The Marantz Reference Table I'm sure is WELL within your price range. Maybe you should just buy that with your $10,000 budget I got off the top of my head. No you won't be wasting money, you'll be gaining money. Hopefully you get the right turntable, good luck. |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 3769 Registered: Feb-05 | Colin, unless you're willing to spend the bucks on a new budget table or a good used vintage deck (likely to cost more than a new budget table by a good ways) you will need luck. Get it? I understand that you may not have the bucks so perhaps saving a little longer might be order. Andre, what's with the $10,000 budget stuff. Colin asked a reasonable question let's try to give him a reasonable answer. |
Gold Member Username: NuckPost Number: 5187 Registered: Dec-04 | Stay with the tour, Andre! |
New member Username: RyukyuPost Number: 9 Registered: Dec-06 | Colin, Did you look at the Audio Technica? It's rated well, has a built-in phono stage, and is in your price range. It really is a nice unit for the money. If you need or want something more, then like Art said, you should think about saving a while longer. |
Silver Member Username: Two_centsPost Number: 791 Registered: Feb-04 | It's possible to find a decent vintage Dual, Thorens or Garrard table for less than $200. Last year, I came across a nicely restored Dual deck for cheap at a stereo repair shop. I was tempted to buy it even though I didn't need another table. It had a beautiful wood plinth and that classic mid-century look. If you can't stretch your budget for a new Rega P3, do some research on some vintage models (not all are good) and look to get one of those. Anytime you're dealing with used equipment you need a little luck. PS, around here you can get a used Technics 1200 for about $300. Another good budget option. |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 3774 Registered: Feb-05 | |
Bronze Member Username: ThereverendPost Number: 11 Registered: Dec-06 | Well, I went ahead and bought that Yamaha YP-B4. I read a few things online saying it is ordinary, and read some posts over at www.audiokarma.com saying that it was a nice, reliable table that "sounds better than it should." It was only $125 and I fugured that this is a fine price for something like that. I think it will serve my purposes fine. As an added plus, it is near mint, has a decent Shure cartridge and was tuned up yesterday. It is from the 70's and has a wood (probably veneered) plinth, an aluminum platter that is probably not heavy enough for most people who read this forum, and a decent looking tonearm. It also came with the manual. Obviously, whoever owned it previously took very good care of it. I played it in the store; it sounded nice enough for me to listen to my used record from the 60's-80's on. I think it will suit me fine for now until I can afford better gear. Now I will have to move onto a decent CD player. |
Gold Member Username: Frank_abelaBerkshire UK Post Number: 1806 Registered: Sep-04 | Colin, Only just got here. Congratulations on your purchase. I concur that given the fact the manual is with it it's probably been well looked after. You say it was tuned up yesterday. Do you know if they changed the belt when they did that tune-up? If they haven't then the belt probably needs replacing if it's some years old. You should be able to take off the platter and have a look. If the belt has any cracks or looks worn or has changed shape (take it off and look at it), then it defniitely needs replacement. I found this location where you can buy a replacement for $14: http://www.turntableneedles.com/index.asp?PageAction=VIEWCATS&Category=21737 Now, the other thing that's an unknown is the cartridge. Although you know it's a decent Shure, do you know how old it is and how much wear is on it? If you're not sure, then either replace the stylus (the most likely source of damage to records) or change the cartridge. Finally, in the case of turntables it's very important to ensure they are sitting on a flat, horizontal surface which doesn't resonate too much. Most important is that the surface is horizontal - as in horizontal if you put a spirit level on there! Second most important is that the surface isn't a sound board. If it resonates a lot (such as a solid wood board) it can cause the deck to be less stable than one would wish since that noise goes straight into it. If you can source some cheap medite or MDF from a hardware store, this has damping properties which may help. I'm not trying to ruin your day, but just giving you an idea of the things you should look at to safeguard your records. Regards, Frank. |
Bronze Member Username: ThereverendPost Number: 14 Registered: Dec-06 | Ok, thank you for your helpful words. I went ahead and ordered both a new Shure M97xE and a new stylus for the current M73PED. There is a problem with distortion at musical peaks, and not just distortion but really hard clipping as if my speakers are blown. I am hoping that a new needle and a decent alignment are all it will take. Your post actually did the opposite, it made my day better rather than worse. Colin |
Gold Member Username: Frank_abelaBerkshire UK Post Number: 1811 Registered: Sep-04 | Blimey Colin! Both a stylus and a new cartridge? Surely the new cartridge would have been enough? Distortion at musical peaks is possible from badly worn records, badly worn stylus, incorrectly mounted cartridge...the list goes on. And what of the belt? Was that in good condition? Regards, Frank. |
Bronze Member Username: ThereverendPost Number: 15 Registered: Dec-06 | Yeah, I thought it would be good to have two cartridges laying around. Now I just need a headshell. I think that the shure that is mounted now is not terrible, so I will keep it. As for the belt, the store owner who sold me the turntable replaced it the day I bought it, so it is fine. Thanks, Colin |
Bronze Member Username: UnderarockMilwaukee, WI USA Post Number: 88 Registered: Oct-06 | Colin, Interesting thread. And I can empathize with your thoughts and decisions. It seems as though once we decide to "upgrade" or "replace" existing gear, a whole new set of problems, and necessary monetary outlay to "fix" these problems, is a natural part of the process. I started out just to get a TT to replace my old Radio Shack belt drive, and ended up with not only a newer turntable, but a new cartridge (and mounting hardware), a new receiver, new speakers, and a good (but used) CD player! Hopefully, you can show more self-control than I did! Good luck with your Yamaha! |
Silver Member Username: Stevestar99Dahlonega, GA Post Number: 117 Registered: Nov-06 | Not sure about what's out there that's new, but the finest vintage TT is the Dual 1219 and 1229. The platers are about 5 lbs. and are super stable. It's just my opinion, I'm sure others have their favorites. |
Bronze Member Username: ThereverendDavis, CA United States Post Number: 35 Registered: Dec-06 | Just resurrecting an old thread My Yamaha is not that great. It runs slow by about a quarter tone, has wow/flutter issues, and etc. I am planning on buying a new Technics 1210 in a couple of weeks and selling the Yamaha to someone who will enjoy it despite the minor speed issues and difficulty in setup. The Technics seems like the very best at this price point. I have also considered buying a used Rega P3 or a restored Dual of some sort (1219 or so). Ultimately I think buying a brand new super reliable table will be my best bet. |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 11111 Registered: May-04 | . Yep, those Regas are always in for repairs. There's so much that can go wrong with them. |
Bronze Member Username: ThereverendDavis, CA United States Post Number: 36 Registered: Dec-06 | I really like the way the Regas look, plus I have a Rega Planet so it would sort of "match." It seems like many people would choose the Technics of the Rega for reliability reasons though, and that is primarily why I would choose it as well. I have not read any really negative comments about the 1200 from any of its owners, and I definitely can't afford to repair stuff all the time. Plus if I start getting antsy with the 1200 I can head over to www.kabusa.com and buy a bunch of tweaks to improve it. |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 11116 Registered: May-04 | . Yep, those Regas are always needin' tweaks. There's so much wrong with them. |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 5239 Registered: Feb-05 | NOT!!! As Jan knows. The Rega is a simple (yet sophisticated) design that is very hearty. They don't have a tank like build quality but let's hope you don't treat them like tanks. Unless you're a scratch DJ the Rega's give excellent sound on a small budget... Whichever you buy just enjoy the vinyl, that's what's important. Support your local record store!!! |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 11126 Registered: May-04 | . And eat locally. |
Silver Member Username: KevincorrFairbanks, Alaska Usa Post Number: 181 Registered: Jul-07 | You should have bought this one: |
