Bronze Member Username: SrkstanKazakhstan Post Number: 50 Registered: Apr-04 | I just bought one of these Jamo subwoofers for a cheap price since it was a blemised new product. I bought it because I was looking for something under $200, which could play music and movies well. Having heard that Jamo is a good brand, I decided to take a risk (since it was under $150 shipped). Being in a remote location, I bought unheard. Does anybody know anything about these subs or have a link to a review? I couldn't find anything on the web in English. |
Silver Member Username: MyrantzPost Number: 269 Registered: Feb-04 | http://www.qualifi.com.au/jamo.asp Sean The above will only give you the specs. Many might say 100wts is not enough. We have a 100wt Richter sub and a fairly large room and still find it necessary to keep the sub's volume down a little. Experimenting with position can go a long way to achieving optimum sound. Jamo is a quality brand and for under $200 you've done well. Good Luck PS: I wouldn't play movies with tanks or cannons to loud where you are ![]() |
