Vienna Acoustics Haydn Grand...
Username: Blowfish
Hi, I am pretty new in the world of Home Audio. I recently went to local Magnolia to listen to some speakers (mostly bookshelf). At first, I liked Def. Tech. studio monitor sm350. But after listening to Vienna Acoustics Haydn Grand, oh my, Def. Tech. sm350 sounds very harsh all of sudden. :-( VA Haydn grand is completely out of my budget. DT sm350 is about $450, and VA is $1200. Only way I can get VA Haydn is by 18 month interest free plan. Do you think VA is worth the cost? I don't have money to upgrade the speaker later, so if I buy a pair now, I want something that I am completely satisfied with. And I am very, very impressed by VA Haydn grand. Audio gurus, what should I do? Show me the way! :-) Are there any bookshelf speakers similar to VA Haydn Grand below $500? I was reading about Monitor audio silver sr1. How MA silver compare to VA Haydn? Thank you very much for your input.
Username: Audionew
Arlington, Texas
Post Number: 12
i like paradigm and would feel comfortable recommending them to anyone.........but i'm a beginner too so dont take my word for it
Username: Audionew
Arlington, Texas
Post Number: 13
that atoms or mini-monitors should be in your price range, some depends on your electronics
Username: Project6
Post Number: 12228
Vienna Acoustics...very nice! Their worth is totally dependent on your perception. If you were impressed, then anything else will be a compromise. If you can listen to Paradigm, try them, but do not buy anything unheard. And the Monitor Audio Silvers will be a little bright compared to Vienna Acoustics.
Username: Stefanom
Silver Spring, MD United States
Post Number: 278
I wouldn't count on anything in the $500 price point touching the Haydn. There is obviously going to be much more competition as you near that price point though, but the ease of acqusition is something to be considered as well (18 months interest free never hurts).
Some speakers you may consider looking at though would include the NHT Classic line (with some speakers in and out of the $500 price bracket), and maybe some B&W speakers.
Of course you should always consider your source and the room acoustics when choosing a speaker, so keep this in mind as well.
Username: Pjsuss
NY
B&W CM1 are about $900. I liked the Vienna better though. Still trying to make up my mind on my system. I also liked the Sonus Faber Concertino bookshelf, but it goes for the same price as the Vienna.
Username: Darth
The woodlands
Post Number: 110
Sam Lee,
The Viennas not only sound pretty good but they look very nice too! but before you pull the plug keep in mind that they are rated at 4 ohms so you will need an amp that is capable of driving them with no problems.
Good luck
Username: Pjsuss
NY
I am going with the rotel rx-1052 amp, rcd-1072 cd - Now I just need to pick out a sub.
