NAD T762 macro
matty b
I cannot seem to get my 762 remote to run a macro that includes the ON button. I'm trying to create a macro that will turn on the amp, then the DVD, then the TV, then switch to satellite input. The amp turns on, but no other components will power up.
I have even tried creating another macro that only turns on the TV, to no avail.
If I just hit TV, then ON, or DVD then ON, everything works fine.
Is there some trick that I'm missing in the setup of the macro?
Thanks.
