Bronze Member Username: Rock_hardPost Number: 36 Registered: Sep-06 | I'm not new to the whole audio/home theater scene but i'm new to amplifiers! right now i have a HK 330 receiver, but i'm going to be building fairly large DIY speakers and wondered if its gonna be underpowered. I see on the back of the receiver it has preouts...does that mean i can use it as a preamp? next..i used to work at a theater and saw they used QSC and Crown amps so i started to search for them...found a few good deals. what are these amps like? |
Platinum Member Username: Project6Post Number: 12196 Registered: Dec-03 | "I see on the back of the receiver it has preouts...does that mean i can use it as a preamp? " Yes, you can! QSC and Crown amps are great professional amps. Works great for demanding environments but a little harsh for home use. I wouldn't rule them out. |
Bronze Member Username: Rock_hardPost Number: 37 Registered: Sep-06 | Hmmm...a little harsh for home use? as in loud...but not very warm? I was searching on ebay and couldnt' beleive some of their prices...can you suggest something a little better for home use? |
Platinum Member Username: Project6Post Number: 12197 Registered: Dec-03 | Harsh as in, harsh on the ears. It shouldn't be too bad if you are using the HK as a pre-amp. What is your budget? |
Bronze Member Username: Rock_hardPost Number: 38 Registered: Sep-06 | Well i really don't have a budget as of yet..this just kinda popped in my head lastnight! I found a couple on ebay for around the $250 range...i know that's very little for an amp but that's what sparked my interest. |
Bronze Member Username: Rock_hardPost Number: 39 Registered: Sep-06 | what about Behringer? is that decent for home use? |
Platinum Member Username: Project6Post Number: 12201 Registered: Dec-03 | If you want loud and cheap then you are on the right track |
Bronze Member Username: Rock_hardPost Number: 40 Registered: Sep-06 | haha i'm not sure i like the sounds of that... i just came across the A500. http://forums.audioholics.com/forums/showthread.php?t=17004 seems to be pretty decent for the price.. will it be OK for home theatre? it wont' sound very clean? |
Platinum Member Username: Project6Post Number: 12202 Registered: Dec-03 | I've seen Behringers used for HT and they are not bad at all. |
