Bronze Member Username: PatrickbatemanMA Post Number: 46 Registered: Oct-05 | <http://www.widescreenreview.com/news_detail.php?id=12512> December 28, 2006 Monitor Audio Raises The Bar With The Introduction Of The Flagship Platinum Range Platinum loudspeakers are a sophisticated blend of craftsmanship and science created from the finest materials and leading-edge technologies. The challenge for Monitor Audio's design team was to achieve the most natural sound possible by focusing on every detail, however small or seemingly insignificant. Unique materials and a purist design approach have transformed our loudspeaker performance to another level, setting the benchmark for all others to follow. The new Platinum range is the epitome of British craftsmanship, quality, and Monitor Audio's award winning sound. Finally, every speaker is carefully hand assembled in England and tested in our anechoic chamber to exacting standards. Platinum C-CAM Ribbon Tweeter Our ribbon design uses an ultra-thin enforced sandwich of C-CAM (Ceramic-Coated Aluminum Magnesium) alloy suspended in a powerful transverse magnetic field of high-energy NeFeB rare earth magnets. The ribbon serves as both voice coil and radiating diaphragm, with every part of the ribbon driven directly and simultaneously without energy storage. This means the Platinum ribbon tweeter provides very fast transient response and is able to start and stop in an instant, perfectly reproducing the leading edge and natural decay of complex musical sounds and their harmonics. The ribbon is capable of ultra-wide bandwidth with a useable frequency response to 100 KHz and is more than capable of producing sounds and all harmonics found in today's hi-def wide-band formats, such as DVD audio, SACD, Blue Ray, and HD-DVD. Platinum RDT (Rigid Diaphragm Technology) Mid-range and Bass Drivers A core of honeycomb Nomex material is sandwiched between ultra-thin skins of C-CAM alloy. These skins are only 40uM thick or less than half the thickness of human hair. Platinum RDT cones are approximately 150 times more rigid than conventional, single-layer aluminum alloy cones. The hexagonal honeycomb core is the most effective shape to maintain structural rigidity when used in a bonded laminate composition, being ultimately more rigid than a solid structure and possessing a fraction of the overall mass. The aim is to reduce mass and increase cone stiffness so the cone works as a lightning-fast piston. The new concave cone geometry, refined by FEA analysis, provides smooth frequency response and eliminates high frequency break up. Other applications of similar composite construction techniques are used in high-performance aerospace and automobile racing applications such as, fighter jet flooring to Formula One racing components. RDT is a unique design, developed specifically by Monitor Audio for the Platinum range. Platinum ARC (Anti-Resonance Composite) The front baffles, mid-range enclosures, and plinths of Platinum loudspeakers are made of a cast Anti-Resonance Composite material. ARC is a cast thermo-set polymer loaded with minerals to provide very inert, optimally damped components. This type of material is used in high-tech automotive applications and is ideal for high-end acoustic applications where ultimate structural rigidity and vibration damping is required. Platinum TLE (Tapered Line Enclosure) A special tapered parabolic shaped enclosure with a cast ARC front baffle is designed to prevent standing waves and modal resonance. The enclosure's tapered shape, together with the use of graduated damping materials, serves to attenuate upper-range frequencies. All cabinets are built using multiple laminations of wood veneers and shaped to form a rigid one-piece shell, which provides extreme rigidity. Internal enclosure walls are non-parallel to prevent standing waves. A unique 'pin-hole' internal bracing structure provides additional cabinet integrity. Steel bolts tie front and back panels to this 'pin-hole' structure to further enhance cabinet bracing. Finally, Bitumastic damping material is applied to all internal cabinet walls to provide a further level of resonance damping. Platinum HiVe2 (High-Velocity) Ports Platinum loudspeakers feature new HiVe2 port technology that uses a straight rifled design to accelerate airflow and reduce turbulence. HiVe2 ports have the ability to move air in and out much more quickly than conventional ports, resulting in fast and powerful bass with superior transient response. Platinum Terminal Panels and Alloy Spiked Feet Platinum loudspeaker terminal panels are finely machined and plated with pure platinum, providing the best possible contact reliability for cable connections. The terminals feature accurate Micrometer adjustment and are suitable for heavy-duty cables with spade, 4mm plug, or bare wire connection of all types. Machined alloy adjustable spiked feet are used on the PL300, and PL100/ PL350C floor-stands. The feet are meticulously machined from high-grade alloy and anodized to exacting quality standards. Solid 'bullet' spikes are also hand machined from hi-tensile steel and chrome plated to a mirror finish. For hard or solid wood flooring, a non-slip rubber pad is integrated into the foot design. C-CAM Our renowned C-CAM (Ceramic Coated Aluminum Magnesium) alloy is an innovative material that exhibits ideal mechanical properties for use in high performance loudspeaker cones and diaphragms. C-CAM is extremely rigid and light, resulting in accurate sound reproduction and high overall efficiency. The C-CAM material is utilized in the construction of Platinum ribbon tweeters and RDT mid-range and bass driver cones. Strathspey Leather Front Baffles The front baffles on Platinum loudspeakers are hand-upholstered using Strathspey leather. Strathspey is the best quality natural leather available and is used in exotic furniture, automotive, and marine applications for the most quintessential British products. Strathspey adds a warm, tactile feel and provides a traditional, high-quality furniture appearance, allowing Platinum speakers to blend easily into any décor. Piano Lacquer Santos Rosewood and Ebony Wood Finish Options Platinum loudspeakers are available in hand-selected, piano lacquer Santos Rosewood or Ebony wood veneers. The wood veneer is hand-applied using traditional furniture techniques, ensuring precise grain matching and no joint visibility. Then, eleven layers of clear gloss piano lacquer are applied. The Models Platinum 100 The PL100 is a compact two-way loudspeaker featuring one 6.5-inch RDT bass-mid driver and a C-CAM ribbon tweeter. The PL100 produces superior bass definition and articulate mid-range akin to the most accurate studio monitors. The extraordinary PL100 has the ability to reach bass frequencies previously unattainable in such a diminutive package. PL100 dimensions: 14? x 8 x 11? inches (HxWxD) Optional, dedicated floor stands are available which can be bolted directly to the PL100 cabinet for increased stability and performance. The PL100 stand allows an increased level of tilt to enable optimum set up and positioning. The PL100 Stand is 24-inches tall. Platinum 300 The PL300 is a three-way floor-standing loudspeaker featuring two 8-inch RDT bass drivers, one 4" RDT mid-range driver, and a C-CAM ribbon tweeter. The PL300 is a true wide-bandwidth speaker system and is able to cover an astonishing frequency spectrum from 28Hz--100 KHz. The RDT mid-range driver is dedicated to producing frequencies between 550Hz and 4 KHz with extreme ease and clarity, thanks to its ultra-light RDT cone. A special, bullet-shaped ARC mid-range enclosure provides an inert and well-damped chamber that is designed to prevent standing waves. PL300's crossover is mounted in the cast ARC plinth to eliminate magnetic interference and provide acoustic de-coupling from the speaker itself. The ARC plinth also houses the bi-wire speaker terminals and provides convenient floor-level access. PL300 dimensions: 43? x 11? x 14? inches (HxWxD) Platinum 350 Center The PL350C is a 3-way, four-driver center channel speaker featuring the same driver compliment as the Platinum 300 Floorstanding Loudspeaker. The PL350C has the ability to reproduce frequencies from 32Hz--100 KHz, making it one of the widest bandwidth center speakers available. Like the PL300, the PL350C's RDT mid-range driver operates in its own ARC mid-range enclosure. Neutral tonal balance and sound that is clear from any kind of distortion or resonance makes it perfect for reproducing crystal clear dialogue. More than 60% of the total sound balance in a theater system is funneled through the center channel, that makes it all the more important to make sure it's up to the job. But just as important, the speaker must be capable of matching the bandwidth and dynamic range of the front/main speakers in the system. Performance and tonal balance from the PL350C is matched to the PL300 and PL100, which makes it the ideal center speaker choice when building a Platinum multi-channel audio/video system. An optional PLC Stand is available to provide straight or tilted positioning. The twin-pillar PLC Stand is 13?-inches tall. The Platinum Range will be available in May 2007. MSRP: Platinum 300: $8,995.00 Pair Platinum 100: $4,295.00 Pair Platinum 350C: $4,295.00 Each Platinum 100 Stand: $695.00 Pair Platinum PLC Stand: $495.00 Each About Monitor Audio Monitor Audio designs and manufactures British loudspeakers and music systems of the highest quality. Since 1972 Monitor Audio has been at the forefront of loudspeaker technology, perfecting the implementation of metal drivers. It is renowned for exemplary speaker cabinet construction and finish. Kevro International Inc. is the exclusive distributor of Monitor Audio products in North America. To find out more about Monitor Audio see www.monitoraudiousa.com. Report Post |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 9574 Registered: May-04 | . OK, why'd you post this here? |
Bronze Member Username: PatrickbatemanMA Post Number: 47 Registered: Oct-05 | new speakers, thought someone might be interested |
Silver Member Username: StefanomSilver Spring, MD United States Post Number: 269 Registered: Apr-06 | I love marketing... Platinum HiVe2 Ports sounds pretty darned impressive. I wonder, Tim do you have any plans to implement this revolutionary technology in your speakers? |
