Problem with Paradigm's
Username: Kevin8985
Hey guys this is my first post, and I'm new to the audio world. I bought an onkyo htr- 502 around 2 years ago, as well as some paradigm moniter 9's for the front. I had them for about 4 month's and just realised that the right speaker has much less bass responce then the left, tried switching the speaker wires and it didn't make a differance. Also noticed that through the port hole there is no air moving even at fairly high volumes as, but the other speaker does. Any help would be awsome.!!! thanks kevin
Username: Jan_b_vigne
Dallas, TX
Post Number: 9568
The speakers should still be under warranty. Take them back to the dealer for an inspection.
Username: Chhipli
Post Number: 8
Did you try putting the right speaker to the left channel to make sure it is not an amp issue? Is that what you are referring to as switching wires?
Username: Kevin8985
Yes I did try switching speakers, but it made no difference at all, I'll try taking them back. Thanks for the help guys !!
Username: Gavdawg
Post Number: 170
Do you remember ever smelling something like burning plastic or smoke?
