Sub won't power up
Username: Nuck
Post Number: 5083
The Velodyne DP12 sub used to self power with one click of the amp(#1 on the dial.)
Now it takes #4 on the dial, which is too loud for some listening.
The amp is straight Class 'a'.
The volume knob goes to 60.
I hate cheap shite that slows me down.
The sub is new, under warranty, but Buddy says that my problem is not grounds for a warranty job.
The sub is speaker level inputs only(all I have).
Should I just shuffle off to Buffalo and go to M&K?
Username: Jan_b_vigne
Dallas, TX
Post Number: 9554
Buy less efficient mains.
Username: Nuck
Post Number: 5088
Thanks for that, pal.
What sub are you dreaming up, JV?
As a box, I liked Bvan's http://www.customanalogue.com/sub_index.htm
Or are you trying an IB?
