New member Username: ThieveryfanPost Number: 3 Registered: Dec-06 | OK, That yamaha I was looking at is gone (Ebay). Which of these two should I get? Harman Kardon AVR-245 or Onkyo TXSR604 They seem very similar, I'm looking for HDMI and Zone 2. Or am I missing another better receiver for the same price? Ciruit City has the Onkyo at 395 with tax until midnight tonight (tomorrow's ad says $499!) Thanks Guys. |
Gold Member Username: NuckPost Number: 5081 Registered: Dec-04 | Kurt, if they both do what you want, pick the one which is heaviest and has the higher power consumption. ie: if the unit says 7x100w, but consumes only 450w, it is either a perpetual motion machine(get 2) or the cure for the worlds power issues. |
Silver Member Username: GamerdudeOntario Canada Post Number: 333 Registered: Apr-06 | H/K ![]() Allso look for the omne which consumes the most power like Nuke said The Onkyo Tajes 7 Amps Considering 0.8amps=100watts (so i have heard) Looks lik the onkyo might be a little more powerful, its all in what you like allso |
Silver Member Username: GamerdudeOntario Canada Post Number: 334 Registered: Apr-06 | Nuck** One** Like** Takes** |
New member Username: ThieveryfanPost Number: 4 Registered: Dec-06 | Well, I bought the Onkyo, the good deal made me jump and I like the back layout - I think the 2nd and 3rd zones are better in the Onkyo too. I hope it sounds good with my Mirage Omnisats (haven't heard them yet). I'm putting it inside a cabinet, any suggestions on how big a fan I should build into this piece of furniture - diameter, CFM? Also, a simple IR bridge that I can take a long run wire and attach it to the back of the receiver? Thanks for the help again - what's Nuck** One** Like** Takes** mean???? ha |
Silver Member Username: GamerdudeOntario Canada Post Number: 335 Registered: Apr-06 | http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=17234 76&CatId=2216 Nice kurt either amp would be perfect Check out that fan its 130mm Noise Level 16 dBA Air Flow 54.4 CFM Two or three of these would be perfect and there pretty qiuet And the **Nuck one** , was me correcting my mistakes Good luck with the case dude |
Silver Member Username: GamerdudeOntario Canada Post Number: 336 Registered: Apr-06 | acually i dont no about the onkyo, but the H/K has two fans inside , but i keep mine open on top of my audio rack , like i said good luck with the case |
Gold Member Username: NuckPost Number: 5102 Registered: Dec-04 | Kurt, was it the heavier one with the higher power consumption? |
Silver Member Username: GamerdudeOntario Canada Post Number: 337 Registered: Apr-06 | H/K-30 lb (13.6kg)//65W idle, 540W maximum (7 channels driven) Onkyo-25.1 lbs/// i couldnt find any info on the onkyo for power consumption |
Bronze Member Username: AfrogtPost Number: 36 Registered: Dec-03 | You made the right choice, even though the HK is heavier is doesn't process audio via HDMI. You'd have to use an optical or digital coax connection. |
