Help with Pioneer Pl-510a
Username: Helensg
I have recently dragged my Dads old record player out of the cellar. Have connected it up ok, but there is no grounding wire, or any place that I can see I can connect one. Consequently I have the old humming problem.
Have searched the internet for a manual but no luck. Can anyone help me please, I know I need to ground it but just can't see how?
Thanks
Helen
Username: Jan_b_vigne
Dallas, TX
Post Number: 9551
You are asking for information specific to the PL510 that has long since evaporated from my memory. Try removing the bottom cover plate and touching a ground wire to the base of the tonearm and the receiver/pre amp's chassis. Preferrably you want to attach the wire to a mounting screw at the base of the arm. This should solve your problem and then only leave you with the issue of making the connection permanent at the player's end.
