Polk CS2 thoughts
Username: Yusuf
I just purchased polk M10 as front and rear.
Now, I plan to add center speaker. Any opinion on CS2 or suggestion of alternate center speaker.
Thanks
Yusuf
Username: Arande2
400dB could probably d..., 4000 isnt ev... 100,000dB FU...
Post Number: 435
Budget? What are you looking for?
Username: Nuck
Post Number: 5055
Yusuf, your choice of cneter speakers should be focused on the polk series that you have now, to match the fronts you have.
It would be my 3rd choice to try another center.
I havn't heard the M10's hope you like them, I liked Rti10's when I heard them, with H/K.
Username: Yusuf
Nuck,
M10 are good but need separate subwoofer for any useful bass.
Yusuf
