New member Username: KimlnPost Number: 1 Registered: Dec-06 | Hi i recently got a Matsui 2GB MP3 player for xmas. ive managed to put songs on the player but i cant work out how to sort them into seperate files to make it easier to find certain songs. when the player is connected to the computer it shows the songs sorted into files, however when i click on music on the player it just goes straight to the first song it seems silly that with 500 songs there is no way of sorting them if anyone could help i would be really greatful as at the moment it is near impossible to use thanks k |
New member Username: Alan_tPost Number: 1 Registered: Jan-07 | Kimberley, this is a known issue, more details here: www.forums.cnet.com/5208-7595_102-0.html?forumID=71&threadID=218044&messageID=23 20425 Try taking it back to exchange for a one of the later units with updated software, probably help if you can get hold of the original receipt. Regards, A. |
New member Username: SamvitPost Number: 1 Registered: Jan-07 | hi i am a user for matsui 1 gb mp3player.i am not able to format through the computer . the mp3 player says "flash error pls format the drive and backup the files ". can please anyone help!!!!!!!! |
New member Username: Alan_tPost Number: 2 Registered: Jan-07 | Samvit, Follow the link I posted above - lots of advice on this issue there, including formatting of the drive. Good luck! Alan. |
New member Username: SamikenPost Number: 1 Registered: May-07 | hi i am a new matsui 1 gb mp3player user.when i play my mp3 the message says "flash error pls format the drive and backup the files ". can anyone help me please!!!!!!!! |
New member Username: JulietashPost Number: 1 Registered: Jul-07 | i recently bought a matsui mp3 player and accidentally formatted it,really need advice.what should i do> |
