Bose speaker grille repair
Username: Vitony
I need to replace the speaker grilles on my bose speakers. Accoustimass 7 series.
How can I remove and replace the grilles
Username: Gamerdude
Ontario Canada
Post Number: 310
Flat head screw driver
Username: Chitown
Post Number: 1319
Jammed straight through the middle of the thing
Ken I don't think you can remove them.
Username: Gamerdude
Ontario Canada
Post Number: 318
yea bose is evil like that, They dont want you taking apart there stuff
Username: Stang
Use a pocket knife. Carefully put the sharp part of blade, the full length, between the grille and the enclosure(On the side of speaker). Now, gently pry up. The grille is press-fit on. It's been a while since I pulled off one of my grilles, so you made need to do the same procedure, except with the knife on the top/bottom of speaker.
