Boston SW 10 sub
Username: Kiefer02
Post Number: 14
It's 10 years old, has always sounded great, but all of a sudden it has a vibrating sound. any ideas?
Username: Nuck
Post Number: 4896
tighten the screws and go shopping on Boxing day?
Whoop!
Username: Jan_b_vigne
Dallas, TX
Post Number: 9485
While you have the grill off to tighten the screws, check the driver's suspension. If it is foam it has probably deteriorated. If it is paper or rubber, it may be torn.
Username: Nuck
Post Number: 4924
Whatever.
If it's broke or worn, you get to shop!
Whoop!
