Question
I am looking at buying a set of loudspeakers and a home theatre system. I am interested in the Fluance SV-10 loundspeakers and the Fluance SX-HTB home theatre system. I don't know much about speakers so my question is will these speakers together be able to play hard rock loudly and sound good and will the subs be able to shake me some when a car blows up on the big screen?
If not can you recommend me some some good loudspeakers and sound systems.
Here are the specs.
SV-10
System Type: 3 Way - 4 Driver Floorstanding Main Speakers
Tweeter: 1 inch Neodynium Balanced Silk Dome Ferrofluid Cooled
Midrange: Dual 5 inch Polymer Treated with Butyl Rubber Surrounds in Separate Sealed Enclosures
Woofer: Side-firing 8 inch Polymer Treated High Excursion with Butyl Rubber Surround
Power Handling: 50 - 200 Watts
Frequency Response: 42 - 20K Hz
Sensitivity: 87±3dB
Crossover Frequency: 800/3500 Hz Phase Coherent - PCB Mounted Circuitry
Impedance: 8 Ohms
Cabinet: Precision Crafted MDF Internally Braced
Enclosure: Tuned Rear Port Bass Reflex Tower Design
Dimensions: 40.3 x 6.4 x 14.4 inches (H x W x D)
Weight: 38.7 pounds/speaker
SX-HTB
Front Speakers:
System Type: 2 Way - 3 Driver Floorstanding Main Speakers
Woofer/Midrange: Dual 6.5 inch Poly-coated Drivers with Butyl Rubber Surrounds
Tweeter: 1 inch Neodynium Balanced Silk Dome Ferrofluid Cooled for longer life
Power Handling: 50 - 160 Watts
Frequency Response: 49 - 20K Hz
Sensitivity: 86±3dB
Crossover Frequency: 3500 Hz PCB Mounted Circuitry
Impedance: 8 Ohms
Enclosure: Bass Reflex Design Internally Braced
Dimensions: 38.75 x 7.75 x 13.0 inches (H x W x D)
Weight: 33.45 pounds/speaker
Rear Speakers:
System Type: 2 Way - 2 Driver Surround Speakers
Woofer/Midrange: 4.0 inch Driver
Tweeter: 1" Neodynium Balanced Dome Ferrofluid Cooled for longer life
Power Handling: 30 - 100 Watts
Frequency Response: 80 - 20K Hz
Sensitivity: 83±3dB
Crossover Frequency: 8000 Hz PCB Mounted Circuitry
Impedance: 8 Ohms
Dimensions: 8.8 X 5.25 X 6.98 inches (H x W x D)
Weight: 5.1 pounds/speaker
Center Speaker:
System Type: 2 Way - 3 Driver Center Channel
Woofer/Midrange: Dual 4.0 inch Poly-coated Drivers
Sensitivity: 83±3dB
Impedance: 8 Ohms
Dimensions: 5.24 X 15.8 X 7.9 inches (H x W x D)
Weight: 9.0 pounds/speaker
Other information at www.fluance.com
Total price is a little bit under 700 bucks.
No I am sorry but it will not be as loud as other systems. The sensitivity is too low for headbanging loudness. Sensitivity of 87 is typical of smoother sounding speakers, but a speaker with a sensitivity of 90 needs 1/2 the power to reach the same volume and sensitivity of 93 means that you need 1/4 the power to reach the same volume. Furthermore if you find a speaker with a sensitivity of 97 it will play twice the volume(every 10dB doubles the volume). So sensitivity of 87dB at 1 watt and a max power of 200 watts means that the speaker maxxes out at 110dB but a 97dB sensitivity speaker with 100 watts max power reaches 117dB(nearly twice the volume) with 1/2 the amplification. If you are looking for loud rock look into Klipsch. Or if you don't want to spend as much maybe DCMs.
