Rega brio 3.....
Username: Malco49
Baltimore, Maryland Usa
Post Number: 30
ok so my one year or so old cambridge azur 540A just starting "crapping out" on me....seems to cut
off after a certain point and/or if volume is raised too high.(and i dont think i have a short circuit connections have been checked and re checked).
what to do????
since i use vinyl as well as CD i need an intergrated amp with phono stage for my two channel stereo.
considered the NAD325bee but would need to add a phone stage
decided on the rega brio 3(with phono stage) bought it for $600(usd)and change
to go along with
pro-ject debut III turntable
denon dcm290 cd player
and
psb image b25 bookshelf speakers
any thoughts? good choice?
and/or have i entered the world of the "upgrader"???
Username: Artk
Albany, Oregon USA
Post Number: 3709
The Brio is a fabulous budget amp and does justice to vinyl. I'm not sure what piece you are asking about. All gear choices are subject to other variables than just the quality of the piece. There is the application..what do you need from the piece. There is synergy...what gear will you be using the piece with. There is musical preference as well as bias around what you believe a system should do or be about..are you looking to reproduce the live experience as closely as possible, do you even listen to live music? Lots of variables......
Username: Malco49
Post Number: 31
thanks for the feedback art.
i was talking about the cambridge amp and replacing it with the brio.
no i dont want to replace the live experience as much as portray the recording quality of whatever i am listening to at any given time.
my first post seems pretty clear in what components i am looking for,i like to hear clarity in the music good separation of the instruments and vocals.
i listen to all kinds of music.some times cranked and sometimes not.
was wondering if the brio would "outpace" the other components listed,i currently have a cambridge AZUR 540A which was "crapping" out but now seems to be on the rebound.
thanks again art
Username: Artk
Albany, Oregon USA
Post Number: 3710
I've found that Rega gear really matches well with it's own and similar pieces. The Project table would work alright with the Brio. The PSB's don't on the surface seem like a good match, as they are not quite as lean and quick as the speakers I believe the Rega amps (like their own) really work well. You're probably looking to upgrade the Denon soon, and if you are the Rega Apollo with the Brio is a match made in heaven.
Username: Malco49
Post Number: 32
cool beans art
what if any cd player is the best 5cd changer?
i actually just got the denon as it seemed to be the best 5cd changer around.
i just like the way you can load a changer up and let it rip! i will research the speaker issue a bit more,although i like the bass on the PSB.
what amp fits the PSB image B25 better? something
in a 50watt per variety.
art i have enjoyed reading your posts over the years.
i am a musician so my listening is maybe more subjective and not as analytical as yours.
and truth be told i did set up my system based on budget.
when i bought the speakers i tried out three bookshelf a KEF and a focal JMlab(?) and thought the PSB's sounded fuller.
Username: Mike3
Wiley, Tx USA
Post Number: 218
MWF -There seems to be a couple of contradictions with your posts.
You declare "i like to hear clarity in the music good separation of the instruments and vocals.", but follow that up with "i just like the way you can load a changer up and let it rip!".
Then as a musician you articulate "my listening is maybe more subjective and not as analytical as yours." The more I play my guitar, the more objective I am becoming with my music. I find that to be true of musicians I have met.
Art is giving you a very good lead on the Rega Apollo. It would be worth your while to audition it and then determine if a changer may be a better component for your system.
Username: Malco49
Post Number: 33
once again thanks for the information.i am going to audition the rega brio 3 with the rega apollo.
regarding the subjective/ojective stuff well let's just say that i am not able to articulate the what how and why i listen to music.
but at least we all love music :-)
Username: Frank_abela
Berkshire UK
Post Number: 1754
Mitchell,
The Debut III is a good basic deck, but that's about it. The standard cartridge it comes with is the OM5 which is a bit of a nail, too. If vinyl replay is important to you I suggest a better deck such as Project's own eXpression or one of Rega's, but failing that consider a better cartridge to help get some resolution and clarity.
5CD changers are all very well and they are quite convenient, but if you really want convenience in a bag you should be looking at something like an iPod. You can store your CDs in a lossy compression mode which lowers sound quality but raises capacity or you store them as lossless and store only a few hundred CDs on one iPod at full CD-like quality. The iPod would probably outperform your 5CD changer quite handsomely if you do this.
The Apollo will beat the iPod in whichever format.
Regards,
Frank.
Username: Malco49
Post Number: 38
frank
what do you recommend as an "appropriate" cartridge upgrade for the pro-ject debut III? would upgrading to the OM 10E make a big difference?
Berkshire UK
Post Number: 1761
Mitchell,
I was thinking more of an Ortofon 510 or 520. The OM range are really quite limited and I think this is because of their limited body integrity.
Regards,
Frank.
