Technic 1200 Ground Wire fix.
Username: Deploy
Hello everyone.
I recently broke the "U" shaped plug of the ground wire that connects to the back of mixer. Ground wire still works, but I want to be able to put that piece back together. Would super glue or some of the sort work just fine? Just curious. Sorry for the newbie question.
Username: Project6
Post Number: 11713
Just go to Radio Shack and get another "U" connector. You can just crimp it on the ground wire. Don't use superglue, it is not an effective conductor.
Username: Deploy
Thanks for the reply Berny.
Username: Jan_b_vigne
Dallas, TX
Post Number: 9426
Do nothing. The spade lug is for convenience only and is not needed for a good connection. A bare wire connection is better than anything else and far better than a poor spade lug connection.
