New member Username: Viperdv2k4Post Number: 1 Registered: Nov-06 | hey im trying to hook up my electronic keyboard to 2 speakers that i have. The only inputs i have on the speakers are 2 holes, positive and negative. My brother hooks up these speakers tolisten to music etc using a reciever and copper wire. im wondering if i can directly connect the keyboard's 1/4 instrument jack directly into the speakers using some sort of converter without using an AV receiver? Thanks for the help!! ![]() |
Silver Member Username: Daniel_canadaCanada Post Number: 215 Registered: May-06 | You need a receiver. You need to run fron the 1/4" on your KB to a pair of the RCAs on the back of the receiver. You can get a 1/4" to RCA anywhere. |
New member Username: Viperdv2k4Post Number: 2 Registered: Nov-06 | oh.. i know u can get a 1/4 to rca, but didnt want to pay so much money for a reciever. are there any cheap crappy recievers that i can buy? i will only be using it to connect my keyboard, so it doenst need any options such as surround sound etc.. or even radio.. |
Gold Member Username: NuckPost Number: 4694 Registered: Dec-04 | A cheap crappy receiver would be a panasonic xr55. |
New member Username: Viperdv2k4Post Number: 3 Registered: Nov-06 | well i dont mean necessairly crappy, just very cheap. ![]() |
Silver Member Username: Daniel_canadaCanada Post Number: 217 Registered: May-06 | You need the power of the receiver to make any sound, you might get some sort of chicken scratch with a direct hook up. You NEED a receiver/amp, look at a local music store, they might have something used. |
Gold Member Username: NuckPost Number: 4696 Registered: Dec-04 | Not without buying a bunch of stuff that equals a receiver. Your brother won't help? Did you tell mom? |
Gold Member Username: NuckPost Number: 4697 Registered: Dec-04 | If the GD edit worked, I would have dropped that last post for being snarky. But not the one about the Panasonic receiver. |
New member Username: Viperdv2k4Post Number: 4 Registered: Nov-06 | hmmm... i have a keyboard amplifier that i can use Stereo out to output the sound. Is there anything that converts the stereo out plug (looks like this http://www1.istockphoto.com/file_thumbview_approve/902801/2/istockphoto_902801_m icrophone_cable.jpg) to the speaker wire? |
Silver Member Username: Daniel_canadaCanada Post Number: 221 Registered: May-06 | Keyboard amplifier? Does it not have speak0r outputs of some sort? |
Platinum Member Username: Project6Post Number: 11667 Registered: Dec-03 | You need to go to a music supply store and get an amplifier for musical instruments, makes it easier to use the proper jacks that you currently have. Just say "no" frankenstein set-ups. Connecting directly to the speakers will not work unless your keyboard has an onboard amplifier for external speakers. |
Silver Member Username: Daniel_canadaCanada Post Number: 223 Registered: May-06 | Yeah, what Berny said. |
Bronze Member Username: SerniterPiscataway, New Jersey USA Post Number: 95 Registered: Mar-06 | How about the T-amp? Not very expensive... http://www.partsexpress.com/pe/showdetl.cfm?Partnumber=300-952 |
Bronze Member Username: SerniterPiscataway, New Jersey USA Post Number: 96 Registered: Mar-06 | More conventional alternatives: http://www.bestbuy.com/site/olspage.jsp?skuId=7016481&type=product&productCatego ryId=cat03031&id=1099394773324 http://www.accessories4less.com/cgi-bin/category/StereoReceivers |
Platinum Member Username: Project6Post Number: 11673 Registered: Dec-03 | loser holla, If you have XLR outputs, you may want to try this http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=248-472 and this one you can use straight out of the box http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=248-737 |
New member Username: Viperdv2k4Post Number: 5 Registered: Nov-06 | i have a keyboard amplifier, with speakers on it, but the speakers dont sound that great. it can amp the sound from the keyboard and output it via XLR. so is there anything that can convert from XLR to speaker wire? |
Gold Member Username: NuckPost Number: 4723 Registered: Dec-04 | yes. an amplifier. Behringer comes to mind. |
New member Username: Viperdv2k4Post Number: 6 Registered: Nov-06 | i have an amp.. alesis sumo 100 |
Gold Member Username: NuckPost Number: 4726 Registered: Dec-04 | If the amp accepts XLR, then you have a conversion from XLR to speaker wire. |
New member Username: Viperdv2k4Post Number: 7 Registered: Nov-06 | i coudlnt find a conversion can you link 1? thanks |
