Has anyone done this? I have an acoustimass 20 speaker system without the head unit and would like to drive the system with the audio out from my computer.
I have a few questions. 1. How do you turn on the amplifier? 2. What are the pinouts for the bose cable (ie which pins are the audio in)?
I had the same question and got the ansvar from Bose that the system has signal sensing on the low-level input. That means that you just connect the PC to L&R on the AM 20 and your fine.
400dB could probably d...,
4000 isnt ev...
100,000dB FU...
Post Number: 216 Registered: Dec-06
I was wanting to hook some speakers up to my computer and just ended up hooking it all straight into my home theater system. I just hooked the digital coaxial audio ouput to the input on my receiver. Then I hooked the S-video to my TV (pic quality is just fine). I'm very happy with this as the power of my home theater owns that of a cheap $200 computer speaker system.
