Looking for speakers matching NAD3130
Username: Arcswe
TaljeSweden
Hi! I am looking for a set of speakers to a recently bought Nad3130. I don't have the posibillity to try them before I buy them.
I could buy one of theese (help me choose)
B&W DM 302 8 ohm
http://www.tnt-audio.com/casse/bw302e.html
http://www.stereophile.com/loudspeakerreviews/542/
Dali 202 4ohm
Infinity Reference 2000.1
Proson Stratego Monitor 6 SAH 150w 8ohm
http://www.technistore.se/prodpics/thmbprosonstratego.jpg
JVC CA-MD9R (speakers)6 ohm 50w (think these ones are crappy)but almost for free at ebay
My plan is to use the kit with a cd and a computer with a very fine sound card. I am also planning to have a subwoofer connected to this system specally for use with heavy computer effects. I am choosing between:
Audiopro Sub Soniq 100w 8"
Eltax Atomic 10.2 175W
I really need help. I am trying to grasp the basics with speakers and amps. I do understand that the 2 kg stereo rated 200w at the local store doesn't have much in common with a and rated 40w in favour to the nad.
System is ment for music and games at close range.
Very grateful for help!
Username: Arcswe
TaljeSweden
I found these ones too [JPW Sonata] in the same pricing range. I do not know much about them...
Username: Arcswe
TaljeSweden
I forgot to tell that it's bookshelf speakers that im looking for, and that CERWIN-VEGA VE-5M is in the same price segment around 180$.
