Parts express project?
Username: Mattman111
Keizer, OR US
Post Number: 58
http://www.partsexpress.com/projectshowcase/magna/index.html
i was looking at this project, but am not sure how the crossovers are put together. how does the project look and what kind of receiver or amp would be best to run them?
Username: Timn8ter
Seattle, WA USA
Post Number: 1128
Parts Express also sells crossover PC boards.
http://www.partsexpress.com/webpage.cfm?webpage_id=3&CATID=48&ObjectGroup_ID=197
The speakers look like they don't need much power to get them going. It depends on what you plan to use them for.
Username: Gamerdude
Ontario Canada
Post Number: 277
http://www.partsexpress.com/projectshowcase/magna/crossover.jpg
Well if you look there
it shows the schematic
Not all you have to do is buy the pc borde and parts and copy it
or do whatTimn8ter said
