I've noticed a slight crackling noise from my speakers, it usually comes from the front left speaker.It happens once in awhile when watching dvd's,I usually press stop and then press resume play and it's gone.Any ideas what this could be!! Thanks in advance.p.s I have a "Monster" coaxial cable and "Monster" speaker cable if that helps .
Derek
Sounds like your decoder is loosing its mind if hitting pause solves the problem. Try another DVD player just to make sure its not that. Unless you are playing your stereo very loud, I doubt it's the speaker (although you could switch front speakers and find out).
