12v trigger
Username: Smiley777
Post Number: 26
which cable do you use to connect?
Username: Jan_b_vigne
Dallas, TX
Post Number: 9319
Normally you build your own to suit the needs of the installation.
Username: Dakulis
Spokane, Washington United States
Post Number: 1055
Go to Rat Shack,
Tell them you want a 12 volt trigger and they will not understand what you're talking about. Same at BB or CC. Then, explain that it's a little doohickey that goes from your amp to your pre/pro and turns it on automactically and it only carries 12 volts and it looks like it plugs into a transistor radio and you might get lucky, or NOT. LOL
