Adcom 555 bridging
Username: Turbyfi
Kernersville, NC US
Can anyone provide enlightment on the specific
connections that need to made to bridge two Adcom
555's to drive a pair of power hungry B&W 801 Series 80 speakers? I know they can be bridged but nothing exist in manual for wiring instructions to do so. Thanks for any input.
Username: Nuck
Post Number: 4488
RT, what pre-amp are you using, how many pre-outs?
Username: Jan_b_vigne
Dallas, TX
Post Number: 9304
Call Adcom for specifics but I think you'll find a DIP switch inside the amplifier that functions as a bridge.
Username: Turbyfi
Kernersville, NC US
I am currently using a Cambridge Azur 640a as a preamp but I have a Dynaco Pat5 on the way (with
the Van Alstine upgrade) The Cambrige only has one set of pre-outs and I'm not sure about the Dynaco. There is a switch on the back of the Adcoms from Stereo to Mono but I don't want to toast my amps or the 801's by "fishing" for the
correct connections. Any advice would be much appreciated. Thanks
Username: Nuck
Post Number: 4497
RT, use an unbalanced splitter from each preout to send to each amp, then use one amp per side.
Dallas, TX
Post Number: 9306
Huh?
Username: Nuck
Post Number: 4498
The left pre-out, install a splitter to create 2 inputs for one amp. Then bi-amp the left speaker with the amp's 2 channels.
Repeat for right.
Dallas, TX
Post Number: 9312
But the question wasn't about how to bi-amp.
Username: Nuck
Post Number: 4502
Oops. Right.
Amps on mono, use left channel input.
Sorry,Randall.
Username: Nuck
Post Number: 4503
And left+ and right- speaker leads. It should be printed on the amp backpanel itself.
