Plasma speakers
Username: Ppaul
Victoria, Glen Waverley Australia
I am looking for a front left,centre,and front right all in one speaker to sit horizontaly under my 42"plasma can anyone help?
Username: Project6
Post Number: 11421
Check out the Yamaha YSP-1. There should be more, but this has been getting attention.
Username: Frank_abela
Berkshire UK
Post Number: 1719
If all you want is the speaker without the built-in amplification, M&K make a 5-channel variant that would sit under your plasma.
Alternatively, have a look at the products from Artison. I know them and think they're pretty good, but they don't make underslung speakers, only side fitting ones.
Regards,
Frank.
Username: Gavdawg
hmmm... Polk Audio makes something called the SurroundBar. I am not sure of the sound quality as I have not heard it.
Username: Ppaul
Have already looked at the Yahama but want to use my amp that i already have and only want front and centre speakers.I believe these incorporate an amp and rear speakers.
Username: Gavdawg
Post Number: 11
The Surroundbar is just the speakers. Check that out.
