Sony audio receiver de885
Charles Cunningham
Can anyone tell me the code to use to control this receiver using another remote? My book says code 222 but it does not work using a mitsubishi remote control.
Charles,
The code will depend on the specific remote you are using. Did your Mits remote come with your tv, vcr or dvd? I assume it came with the tv. All the newer mits remotes come with the codes printed on the back of the remote. Since your codes are in the book that means it might be an older tv. If it is older than 3 or 4 years it may not have the codes for your reciever since it is newer. Write me back if the details vary.
