New member Username: Eric2007Post Number: 1 Registered: Nov-06 | I'm trying to figure out how I can connect non-computer speakers to my computer. Is there any way to take regular speakers (like the detachable ones from a minisystem)--ones with red and black wires--and hook them up to an 1/8th inch jack? I appreciate your help. Eric |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 9288 Registered: May-04 | . Connect the wires from your mini-system speakers to a 1/8" plug. But, unless your sound card has enough output voltage to drive unamplified speakers, this isn't going to work well. |
Bronze Member Username: SerniterPiscataway, New Jersey USA Post Number: 81 Registered: Mar-06 | If the mini-system has inputs, you can use a Y-connector such as: http://www.radioshack.com/product/index.jsp?productId=2453699&cp=2032058&f=Taxon omy%2FRSK%2F2032058&categoryId=2032058&kwCatId=2032058&kw=stereo+to+rca&parentPa ge=search IMO, without amplification, the speakers are not going to produce much sound. |
