I am looking to get an integrated amp for my B&W 604 S3 speakers. Can anyone make a recommendation as to which model would make a good match for my speakers? I will be using them with a tuner and CD player. I don't really want to spend more than $700...THANKS!
any specific reason why you are looking for a NAD? anyhow, bw speakers are rather easy to drive so no worries there with NADs. if you are on a budget, the 320BEE works v well. else, take the 352. generally more powerful amps can control speakers better and therefore produce better sound.
