$500 budget for receiver and speakers
Username: Blacklakelight
Hello, first post, and I know you get so many of these budget questions, so thanks for your patience. I need a receiver and a pair of speakers, and my budget is $500. This stereo will be used in a relatively small room, apx. 17.5'x 14' It will be used for 95% music, all styles but rarely classical.
I'm fine with 2-channel stereo--one of the reasons for this post is I haven't bought new equipment in forever, and all this multi-channel stuff baffles me. Favorite system I ever had was an old Marzantz solid state and klipsch kg4's; ideal would be an old Mcintosh and khorns. Not that I expect such performance, but just so you know where I'm coming from.
I'm considering a HK3480 and Wharfdale diamond 8.2's which I found on sale. Any thoughts or suggestions would be much appreciated.
Username: Project6
Post Number: 11358
You already have a nice system in mind. I say run with it.
Thanks man, that's what I'm thinking, the best I can get for the money. I think it's going to be pretty cool, actually. I have a project system, an old Dyna tube amp and kg4's, but that's going to have to wait until I'm out of grad school and have the time and $$$.
Username: Exerciseguy
Brooklyn, NY USA
Post Number: 567
Brett, just wondering if you picked-up that HK/Wharfedale system and what your thoughts are. It should be killer. On a tight budget, I don't you could do much better.
Brooklyn, NY USA
Post Number: 568
oops, I just saw you posted yesterday. Chime in when you get the system & take it for a spin.
Username: Petergalbraith
Rimouski, Quebec Canada
Post Number: 1946
I'd say save up for a pair of 30 year-old KHorns and refresh the caps on them when you get them. Figure around $2000 to $2200 for the KHorns and $100 for capacitors. I don't find that they need very fancy amplification, and image a they soundstage like crazy, completely disappearing on your 17.5 long wall. The only downside is that you will sit less than 8 feet from your front wall.
They work well for HT too, using at minimum Heresy on the other positions (but maybe your current KG would work out too).
Thanks people, it'll be a couple of months before I actually have it but I need to go ahead and decide. It's a wedding-related system, so Peter, while I like your idea more than you could believe, it won't work in this situation.
I think I'm going with the Wharfdale Diamond 8.3's, though, which I hadn't seen when I first posted. Looks like the same speaker but floor standing, probably better bass response? I may run it by over in speakers to see what people think.
Brooklyn, NY USA
Post Number: 573
Brett,
Buy those 8.3s now they are on closeout @ amazon for $199 + s/h. They will soon be all gone.
P.S. You can save $30 if you apply for an amazon credit card.
Brooklyn, NY USA
Post Number: 574
Another good choice, the Mission M731 for $229 http://www.tsto.com/cgi-bin/TSTO.storefront/453a4eec013f59642740ac10034105f7/Pro duct/View/2393
Brooklyn, NY USA
Post Number: 575
M73i I mean
