Help with McIntosh Amp and Bower&Wilkins speakers
Username: Mista74
Hello,
I have recently had a mcintosh amp, preamp, and tuner refurbished which I have hooked up to my B&W speakers. For some reason there seems to be some distortion/reverb when I play CDs. The tuner is fine. Also, while I was listening to the radio this evening, I heard a tiny pop, and now the right speaker is no longer working. Can anyone make any recommendations as to what I could try?
Thanks!
Username: Jan_b_vigne
Dallas, TX
Post Number: 9212
Where did the "pop" come from?
Username: Mortal_one
Post Number: 47
Show us the way oh Great Yoda Master! Show us the way!
Start with basics, cable connections, fuses. Have you cleaned the contacts? Have you clean the RCA's? Do you think there is a problem with the unit, do you the think it should be taken back? Could it be the speakers?
Username: Mista74
well everyhing has just been repaired. the speakers are new and so is the CD player. I'm thinking it might be the amp because the repairman was having some issues with it.
Username: Nuck
Post Number: 4331
Issues?
Well, that happens. What vintage is the Mac, and model?
