Pioneer 55txi and trouble with Sub
Username: Luizix
I have a Pioneer 55txi and I cannot put a subwoofer (ASW675) enable with music; in movies all channels work, but in Music fails. I'm tired to read the manual and the configuration procedure but i cannot find any hint.
Hockey fan
You need to set your sub-woofer to "Plus" in the system settings. The manual should guide you.
Did you use the MCACC option to calibrate your speakers ?
Username: Elitefan1
Post Number: 403
Are your fronts set to "small"? This will keep the sub preout active in all modes including "direct" which I would recommend for 2 channel music listening.
Hockey fan
Hey elitefan,
Would you recommend this set up even if you have front tower speakers that provide deep bass ?
Thanks !
Username: Elitefan1
Post Number: 405
Probably not. Honestly I would have to hear that set-up to say for sure but I am not a lover of lots of bass for music.
