Proper selection of Small or Large speakers for NAD T753
I just received my new NAD T753 and PSB Image 4T, 1B, 8C, & Subsonic-5i system yesterday and I have one question after reading the NAD manual. It says to select either Small or Large for the speakers depending on the bass response below 80 Hz. The PSB 4T specifications show a low frequency cutoff of 33 Hz which suggests a selection of Large. However, the manual says that if a subwoofer is used then Small should be selected. Do you have any recommendations?
Btw, I selected this system largly based on the posts in this forum and my budget. I also went to Saturdayaudio and with Andy's advice on a few questions I ordered it last Saturday and it arrived yesterday in good shape. Thanks to all for the helpful discussions and advice.
