Harmanaudio's refurbished items: any good?
Hi,
I can get a new AVR230 from JR for 380 w/ free shipping, while a refurbished one goes for about 320 (including shipping) at harmanaudio.com. Does anyone have any problems w/ refurbished items from harmanaudio or refurbished items in general? Thanks for any advice.
Username: Smitty
Post Number: 68
I've never bought refurbished, but from what I read on the boards people generally have good luck with them. If you do get a H/K refurb I would go for the 325Z for $334 instead of the 230Z though.
Kar
I have a HK AVR 325Z (refurbed ver os AVR325) for almost 8 months now ..and no problems whatsover. Certainly would recommend HK refurbs as the warranty is the same 2 yrs
orbit
Smitty,
Is there any other factor that makes the 325 better than the 230 apart from the fact that it is a 7.1 system?
Kar,
When you purchased the refurb was there any physical damage to your equipment? Does HK tell us what was the problem with the equipment?
Thanks.
