HOW TO HOOK UP HK AVR 340 TO SAMSUNG 61" DLP
Username: Motormanmike
WHAT IS THE BEST WAY TO HOOK UP AVR 340 TO
HUGHES DIRECT TV HD REC W/DVI
PANASONIC DVD BURNER
PHILPS DVD VCR COMBO
AND SAMSUNG 61" DLP
I HAVE NO CLUE WHERE TO START,CAN ANYONE START ME OFF I WANT THE BEST MOST CLEAREST WAY NO MATTER THE COST OF CABLES.
Username: Kano
BC Canada
Post Number: 1082
Use a coax 75 Ohm digital audio cable out of the orange output of the cable box into the HK AVR340, and use a DVI-->HDMI cable to connect the cable box directly to the tv. (I think your tv has an HDMI input, if it has DVI just use a DVI cable)
Username: Chitown
Post Number: 1277
Try this.
http://www.ce.org/connections_application/CEA_Connections_Guide_Final_v2.swf
