SPDIF
Username: Nuck
Post Number: 4220
Hey all.
I will run from my Creative Labs stereo digital out SPDIF to my DAC in the lower level.
I find no info from either end as to the requirements for this interface(resistance, etc), or recommended max length of cable run.
Both ends are single end unbalanced connections.
Any thoughts?
Thanks.
Username: Project6
Post Number: 11095
Nuck,
The 75 Ohm digital coaxial cable will have the same limitation like the ones used for analog video. It can be supported for a 100 feet or more.
TOSLINK however is limited to 20 feet and beyond that is prone to signal loss due to internal reflection with cable bends no more than 70mm.
Username: Nuck
Post Number: 4222
Thanks, Bernie. So terminating the coax with appropriate single ends should suffice?
Username: Project6
Post Number: 11096
Yes it would.
Username: Nuck
Post Number: 4224
Thankin' you.
Username: Greenej
Quincy, Ma U.S.
My home pc was fried over the past week and I need to get the files from my IPOD to my new pc. Any thoughts?
Username: Project6
Post Number: 12786
Huh?
You are hijacking the wrong thread! No wonder you fried your PC, LOL!
You cannot transfer iPod music files to another PC. It is a one way transfer.
You need a hack to get the files from your iPod to a different PC. Put "iPod hack" on a search engine and you will get plenty of hits. Just be careful or you may end up with "sad face icon" on your iPod.
