Hey guys. I'm looking into purchasing my first subwoofer for my system. I've been looking at the Dayton drivers mainly, but the subwoofer isn't my main concern.
My current receiver has no sub-out or any type of output for that matter. However, my receiver is not exactly my "pre-amp". I have my system hooked up to my computer as follows:
The signal is actually controlled by my computer, which gave me a bit of an idea that may be able to solve my problem.. In my soundcard output I have an RCA cable, 1-male-to-2-male so it can go into my EQ.
My idea was to buy another 1-male-to-2-male converter, and a 1-male-to-2-female converter. I would hook the 1-male-to-2-female into my soundcard, and then hook the 2 1-male-to-2-male cords into both my EQ and into my Sub, which would deliver signal to both. My only question is if this would work or not.
it's an AKAI AM-A70 .. I don't think you can find anything about it online because it's from 1984-ish and I think AKAI went out of business for awhile or changed something.
It may work, but you could obtain a sub/plate amp that uses speaker line in connections; you connect the receiver to the sub w/ standard speaker wire connectors and then from the sub to your speakers. This would also cross your speakers over at a frequency of your choosing to reduce their burden somewhat.
