Dual 510 turntable help please
Username: Audiofi
I have just purchased a dual cs510 t/t. Problem is the strobe lamp is not working. I have removed all the screws from the bottom panel but neither the bottom or the chassis will seperate from the plinth. I have noticed that the base is stapled to the plinth all round. Do these need to be removed ? Is this the problem ? Can anyone help.
Thanks very much.
Username: Jan_b_vigne
Dallas, TX
Post Number: 9147
There should be several tie down screws on the plinth which need to be manipluated to release the pieces from each other. Check the archives of this portion of the forum. There is a Dual web site listed in several of the threads.
Username: Audiofi
Thanks for writing back Jan.I've already found how to open it and I have removed the bulb. Any idea where to get it from ?
Thanks
Username: Hawk
Highlands Ranch, CO USA
Post Number: 983
I had a Dual 510 turntable that I had to sell when I left the USA to go to England for school almost 30 years ago. Great turntable.
Dallas, TX
Post Number: 9159
Colin, did you check the Dual web page?
