Need help badly! No sound from TV-Denon S101
Username: Tims_44
I just hooked up my new Denon S101 system to my RCA tv.I followed the instructions on the easy hookup guide. I get sound from the dvd player, but when I try to watch tv shows , I get no sound from the receiver. What am I doing wrong. My tv has the RCA connections only. How should I hookup the audio to the Denon receiver. I am not all that ignorant when it comes to electronics, but this has me puzzled. I would appreciate any detailed help. By the way, I do not have a separate cable box. The cable runs directly to the tv. Thanks everyone for any help!
Username: Nuck
Post Number: 4124
If the rca's are marked audio out, check the tv setup to see if the output must be enabled.
The receiver should have tv in marked for input.
Username: Tims_44
Nuck: Thanks for the info. After getting home from work, I figured out that the tv did not have any audio outputs. It was an older model so I went out and bought a Philip's 20 inch. It suits my needs well, and the Denon sounds great when I am watching TV.
