Ipod Mini wont restore to factory settings
Username: Angelicbabe0907
I have an ipod mini and I accidentally pulled it out when it said 'Do Not Disconnect'. And now itunes doesnt recognise it and all my songs are missing. I'm over that though. I just want to get my ipod to work.
Everytime I plug it in I get a popup telling me I must restore factory settings. Now I keep trying to do this, but it just wont work. I've done the whole: toggle the hold switch then press select and menu together till the apple logo appears, then press selct and play together. It just wont reset.
But I've unistalled and reinstalled and updated itunes. Nothing works.
Please Help
Username: Project6
Post Number: 10878
Seems like you have a bad hard drive. Go to apple's website and see if they have a fix for the particular problem you are having.
I've been there. Nothing will work. My ipod is still functioning though. I can go to playlists and stuff, but it has no songs on it, so it's just an expensive paperweight.
Username: Project6
Post Number: 11002
Send it in for repair.
