Thorens td160
Username: Mrcload
hi got a thorens td160 with a shure m75ed. i got some old LPs out it seems to revolve smoothly but i get crackling and loss special on rh side. i no these old ones need setting up. has ne 1 got ne advice on how to do it for a beginer just to get it going. eg wot ere the dials for on the arm. i brought it from a good old fashioned shop that sells all old gear paid £65 for it. they said it was working fine. so guess i just need to fiddle wit it a bit.
thx in advance 4 ne help
regards
chris
Username: Jan_b_vigne
Dallas, TX
Post Number: 9111
Fiddling without knowing what you are doing is the worst thing you can do. Take it back to the shop where you bought it and ask for some assistance.
