Out of the box thinking . . .
Username: My_rantz
Australia
Post Number: 792
Interesting concept,
http://www.soundandvisionmag.com/article.asp?section_id=7&article_id=1279
Username: Manc
Link not workin for me.
Username: My_rantz
Australia
Post Number: 793
It works okay for me, though the speaker is the Jamo R 909 if you want to Google it.
Username: Stefanom
Silver Spring, MD United States
Post Number: 138
Reminds me a little of the Linkwitz Orion. It is indeed an interesting idea, albeit a bit pricey, considering they don't even have to fabricate a box!
Username: Manc
Post Number: 8
Seems like a good idea to avoid box colourations. Pricey indeed but more to spend where it counts more methinks.
Username: Timn8ter
Seattle, WA USA
Post Number: 1067
Nothin' new, but I think you mean "no box" thinking.
http://www.glacieraudio.com/new%20Glacier%20Audio%20Site/Products%20folder/Gilmo re/Gilmoreaudio1.htm
and the aforementioned Orion.
http://www.linkwitzlab.com/orion_us.htm
Dipole speakers tend to be highly directional helping avoid some room problems. The commercial offerings usually have very expensive drivers designed to work in free air to deal with the loss of acoustical suspension and electronic EQ to help the bass response.
Username: My_rantz
Australia
Post Number: 797
Thanks for those links - I'd never seen these designs previously. I read somewhere that it takes a fairly powerful amp to work those R 909's so I suppose that applies to others of similar design considering your comments on the drivers.
Username: Timn8ter
Seattle, WA USA
Post Number: 1068
Dipoles aren't typically power hogs but it depends on the drivers used, of course, and how much equalization is applied. The R 909 is reported to have sensitivity of 89db and 4 ohm nominal impedance which isn't too bad. You can be fairly confident the impedance will dip under 4 ohms so a stout power supply would definitely be in order.
Username: Frank_abela
Berkshire UK
Post Number: 1618
Dey sho' is ugly dem dere speakers man...
