What is the best Portable MD Recorder For Live Music?
Can anyone help me find out what the best MD Recorder is for Recording Live Music? I've found sites that point to Sharp's MD-MT90. Is that correct?
or you can get a SHARP MDDR 7
Username: Kallitype
Vashon, WA
THe Sharp units are superior, in that you can adjust the level while recording. I have a Sharp DR420 H and the sound quality is superb. I use the little "in the ear" microphones which record binaural sound (as opposed to stereo) which is much more lifelike when played back through earphones, but if played through stereo inputs in a hifi system, sounds like regular stereo.
The downside is not being able to use the netMD to transfer digitally to a PC to make CD's, but you can connect the MD recorder to any stereo system and get great sound.
P Floding
In-ear microphones:
Hi Terry!
Could you let us know what microphones those are?
Thanks
CAN YOU ADVISE WHICH MINI DISC RECORDER TO BUY, I NEED IT TO RECORD A STORY THAT I WISH TO SELL ON THE INTERNET. THANK YOU .
Need to Register?
Forgot Password?
Enable HTML code in message
