Linn Sara with Rega Mira 3
Username: Onthebeach
I have a Rega Mira 3 with Rega Ela speakers in an all Rega system. There are a pair of Linn Sara's in really good condition available locally. They have always been a favorite of mine. I was wondering if they would be an improvement over my Elas, and if the Rega Mira 3 could drive them?
thanks
Username: Nuck
Post Number: 3944
Sara, Sara2 or Sara9?
Username: Nuck
Post Number: 3945
http://www.audioweb.com/Review/ReviewViewer.asp?numrows=25&companyid=373&searcht ype=B&sort=M&revieworder=25
What's a Sara 2? It's not a 9.....rounded front edges, single wire cannon connectors...
Username: Nuck
Post Number: 3958
http://www.canuckaudiomart.com/details/36644-linn_sara/
Like so?
Exactly!
Username: Frank_abela
Berkshire UK
Post Number: 1623
With regret I have to say it might be a push for the Mira. If you do buy the Saras, you'll get a lovely sound out of them but not a very loud one. If you're not looking to fill a large room or drive them loud, then you may be on your way to achieving a nice system when you replace the amp (the obvious candidate would be a larger Naim amp such as a 160, 180, or 250). You can build a 'typical' Linn/Naim system from the 70's, with very good results indeed, then.
The Mira will suffice but only in the short term probably.
Regards,
Frank.
