I know next to nothing, please help
Username: Acm_3114
Tulsa, Oklahoma United states
ok, i just bought two 12' audiobahn ALUM12N subs off the net. 1000 w rms each, 2000 w max each. here are some more of their specs that i dont know much about:Dual 6 Ohm Voice Coils, Multi-connect Lug Lock Terminals, Magnet Weight: 120 Oz., Frequency Response: 18Hz-500Hz, Efficiency: 96.4dB, Voice Coil: 3" Dual 6 Ohms, Spun Aluminum Cone. so, basicly what i need to know is what kind of amp would work well enough with these subs. i dont need an exact amp just the specs of an amp that could work so that when i go to buy one i wont pull a dumbass move and buy something i cant use or burns up. almost any advice will help. peace
Username: Project6
Post Number: 10050
Wrong forum Austin. This is Home Audio, you want Car Audio
go here:
https://www.ecoustics.com/electronics/forum/car-audio/4.html
Username: Acm_3114
ha, youre right. thanks
Username: Project6
Post Number: 10051
No worries.
Plenty of knowledge in that area. Look for glasswolf, muddy or Rovin. :-)
Username: Nuck
Post Number: 3884
Berny, you rolled over 10k!
Somebody lube Berny and rotate his tyres!
Username: Project6
Post Number: 10115
Yikes...I was hoping to keep that lowkey...oh well
Username: Nuck
Post Number: 3886
I just canna be sure if the 10k is a good thing or not.
Thanks for all your help, past and future.
Cheers!
Username: Nuck
Post Number: 3887
And crank up all those outlaws today, one crank for the Gipper.(ok for me, then)!
Username: Project6
Post Number: 10135
I would that I could, but alas, I am currently in South Korea and won't be back until the first week of September. :-(
I shall do the that when I get home with a bottle of Mosel :-)
Username: Artk
Albany, Oregon USA
Post Number: 3520
I was just waiting to see if there was a platinum membership. There should be some kind of reward for time spent here on this cyberspace version of the wild wild west.
Username: Project6
Post Number: 10144
Having a moderator to clean up the inbred pond scum should be enough...we can't even get that.
Username: Roamer
Oakville, Ont. Canada
please tell me how to flash or download bin files into the receiver fortec ultra from the computer
thanks.
syd
Username: Project6
Post Number: 10213
Go here, sydney;
https://www.ecoustics.com/electronics/forum/home-video/15133.html
