New member Username: Sb4wvuPost Number: 5 Registered: Jul-06 | Couldn't figure out a better forum to post this question, so here goes... Anyone know where I can order a material to replace the glass on my tv stand doors. At the moment, I keep both doors open to expose my a/v receiver and center channel. Would like to replace the glass with a black material that would allow me to keep the doors closed while permitting the center channel to be heard and the receiver to breath. Any suggestions? Website links? |
Platinum Member Username: Project6Post Number: 10032 Registered: Dec-03 | How about replacing the glass with the same material used for speaker grills? |
New member Username: Sb4wvuPost Number: 6 Registered: Jul-06 | That is one of the options I'm considering...know where I can order the material? thx |
Platinum Member Username: Project6Post Number: 10117 Registered: Dec-03 | Check these: http://simplyspeakers.com/11speakergrills.htm http://www.acousticalsolutions.com/products/fabrics/grille_cloth.asp http://www.speakerworks.net/grill_cloth.html http://www.partsexpress.com/pe/showdetl.cfm?Partnumber=260-335 |
