FM not working
Username: Daz223
I have an old hi-fi system, a JVC MX-C330. It can pick up AM signals but there is absolutely nothing on FM, even when I plug in a small wire on the aerial outlet. Does this sound like something expensive to fix?
Username: Daz223
It's ok, I've found the source of the problem. It needed a better aerial fitted.
Username: Motorbike
I have a Sansui 717 tuner. It plays in AM fine and the signal strength meter works fine. When you push the FM automatic stereo button or the FM mono button you lose 90% volume. It will not play when the mute button is on and signal strenght meter does not work. Also, stereo light does not work.
Username: Jan_b_vigne
Dallas, TX
Post Number: 14715
And ... ?
Sounds like you need an antenna.
Need to Register?
Forgot Password?
Enable HTML code in message
